SDeckB Posted May 19, 2023 Share Posted May 19, 2023 Hello I am trying to learn the material list and all her glory and have a pretty simple question. I've got a 2x10x30 highlighted below. The max length I'd like these to go is 16'. I don't have a 2x10x30 available in the strucutural member defaults. Is there a way to set this to it won't use a 30' board there or should I "install" the boards at the correct length when drawing the framing? Thank you in advance! Tanya Link to comment Share on other sites More sharing options...
javatom Posted May 19, 2023 Share Posted May 19, 2023 Under the build structure tab there will be an option to mark the location of a bearing wall. The joist will then break at that point into 2 shorter lengths. You might have to tell the defaults to NOT align the joists at the break point. Link to comment Share on other sites More sharing options...
SDeckB Posted May 19, 2023 Author Share Posted May 19, 2023 HI, thank you for getting back to me. I'm not seeing the option you mentioned in the structure tab - Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 19, 2023 Share Posted May 19, 2023 27 minutes ago, SDeckB said: HI, thank you for getting back to me. I'm not seeing the option you mentioned in the structure tab - You can designate a wall as a Bearing Wall and joists will break over it. Structure Tab is #2: Or you can draw in a Floor/Ceiling Beam or a Bearing Line with same result: Rebuild framing afterwards. Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted May 29, 2025 Share Posted May 29, 2025 has anyone gotten this to work? what about on a deck? my joists are building in at 20' long and i want to split them to max 12' boards etc. Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 30, 2025 Share Posted May 30, 2025 15 hours ago, TCB_BdnMY said: has anyone gotten this to work? what about on a deck? my joists are building in at 20' long and i want to split them to max 12' boards etc. What exactly are you asking? Do you want to know how to make deck joists automatically break over a beam? Or just to make the Material List only show 12' lengths? Your question is a little vague. Try to be more specific to get better answers. Best to create a new thread instead of tagging onto an older thread, and include a plan file, or at least a screenshot or two describing the problem. Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted May 30, 2025 Share Posted May 30, 2025 1 minute ago, Chrisb222 said: What exactly are you asking? Do you want to know how to make deck joists automatically break over a beam? Or just to make the Material List only show 12' lengths? Your question is a little vague. Try to be more specific to get better answers. Best to create a new thread instead of tagging onto an older thread, and include a plan file, or at least a screenshot or two describing the problem. Thanks for the reply Chris I was trying to get the joists to break & lap over the beam underneath and keep to 12' boards for the build. I did end up making things work by making a foundation level under the deck room and used the bearing lines where i wanted the break. When it was just a deck on level 1 without the lower level, the joists weren't breaking over the beam, with or without bearing lines etc. Link to comment Share on other sites More sharing options...
