jnm-bds Posted May 16, 2023 Share Posted May 16, 2023 I'm trying to create a short walkthrough. I need to go thru a hallway under stairs. When I create the walkthrough, instead of staying at FFL, the video goes up on the stairs into the attic. I've attached the video. Anyone know how to solve this? Untitled video - Made with Clipchamp.mp4 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 16, 2023 Share Posted May 16, 2023 You should be able to set the camera to use an "Absolute" Camera Height and make it work for a short and simple walkthrough. However that is not the way it is supposed to work so please let us know what software version you are using and we may be able to help better. Link to comment Share on other sites More sharing options...
jnm-bds Posted May 16, 2023 Author Share Posted May 16, 2023 Sorry, I changed the floor level from 1 to A and it solved the problem. I don't know why. I'm using Premier X14 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 16, 2023 Share Posted May 16, 2023 2 minutes ago, jnm-bds said: Sorry, I changed the floor level from 1 to A and it solved the problem. I don't know why. Humm..... I am not sure but that may have automatically changed the setting I was referring to above. If you have any more issues please post the plan file so we can better analyze the situation. Link to comment Share on other sites More sharing options...
jnm-bds Posted May 16, 2023 Author Share Posted May 16, 2023 Will do. Thank you for your help! Link to comment Share on other sites More sharing options...
DBCooper Posted May 16, 2023 Share Posted May 16, 2023 There is a setting in your "3d view defaults" called "camera bumps off walls". I think this also controls whether or not cameras will go up stairs. You might want to see if turning this off also solves your problem. Link to comment Share on other sites More sharing options...
jnm-bds Posted May 17, 2023 Author Share Posted May 17, 2023 18 hours ago, DBCooper said: There is a setting in your "3d view defaults" called "camera bumps off walls". I think this also controls whether or not cameras will go up stairs. You might want to see if turning this off also solves your problem. Thank you! I'll check that out. Link to comment Share on other sites More sharing options...
