ComputerMaster86 Posted May 13, 2023 Share Posted May 13, 2023 To anybody that is interested, I am giving access to my revised configuration file for the 3D Connection devices and Chief Architect X15. Keep in mind this is a work in progress. Chief X15.zip Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted May 13, 2023 Author Share Posted May 13, 2023 It does take a little finagling to get the radial menus to load but, once loaded, you should be able to pin those radial menus to the buttons on your device. Link to comment Share on other sites More sharing options...
Jonathan3891 Posted May 15, 2023 Share Posted May 15, 2023 Does this require a particular device to function? Link to comment Share on other sites More sharing options...
someguy Posted May 16, 2023 Share Posted May 16, 2023 On 5/15/2023 at 7:14 AM, Jonathan3891 said: Does this require a particular device to function? A 3d Connexion spacemouse. https://3dconnexion.com/us/spacemouse/ Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted June 2, 2023 Author Share Posted June 2, 2023 If you load my configuration file, it should load the radial menus I have created. That is assuming you have a 3DConnections device. Once loaded, you may have to map the radial menus to the buttons on your own device. In some instances it may override your device and it's existing settings. That is if you have the same device as me. Currently, I have the following... 3D Connections + CAD Mouse Compact (Corded) + 3D Space Mouse 3Compact (Corded) + Keyboard Pro + Numpad Pro (Comes with the Keyboard or Sold Separately) Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted June 2, 2023 Author Share Posted June 2, 2023 Now keep in mind this was tailored to my personal work flow and is actively a work in progress. It's also tied to Chief Architect Premier X15. It may not work with other versions of Chief Architect. As time goes on, I will likely be revising some of the radial menus. I plan on adding more radial menus and macros that are tied to Chief Architect tools and functions. If you are able to access the radial menus, feel free to change and tailor this to your own work flow and needs. Link to comment Share on other sites More sharing options...
tomm11 Posted December 31, 2025 Share Posted December 31, 2025 Are you using a Mac or a PC? I have a cadmouse and I'm not getting anything close to which is showing. Is there something I have to set up on the chief side through preferences? I have everything up-to-date with my macOS and chief + cadmouse Link to comment Share on other sites More sharing options...
para-CAD Posted January 3 Share Posted January 3 On a mac, the 3D mouse works amazingly well in Sketchup. In Chief....not so much. Link to comment Share on other sites More sharing options...
