vertical line on elevation
SHCanada2
This vertical black line just showed up even though I have not changed the exterior walls in a couple days
Any ideas? I see these every once in awhile.
and just now while I was looking I noticed the footing line was about the same place
so for shts and giggles, I turned off the footing layer in plan view, went back to elevation and it is gone. tried to repeat the behaviour and I cannot.
then I was in ortho view and I turned on walls, labels, and then the vertical black lines appeared on the back of the house
and now I cannot get them to go away. it looks to be because of the side wall (below seems to match the lines), but why just show up at random?
then I start fiddling with the wall intersection tool for the one corner, and then poof both corners vertical lines vanish
unbelievable. what am I missing here?
