Resilient channel or other acoustic wall detail components
MovingandShaking
Every case is a little different.
I add the appropriate layer to the walls and/or ceiling. For instance in the wall DBX I'll add a 1/2" space behind the drywall for RC. Perhaps it will need to be a double wall.
Then take a cross section and detail it. If the wall is built up correctly then the detailing should be easy.
