HumbleChief Posted April 12, 2023 Share Posted April 12, 2023 In plan view there's "Snap Unit" which I have set to 1/16" to move for very small adjustments. Is there a similar setting in Layout to reposition layout boxes? It seems to be set on approx. 1" and don't know how to change that setting. THANKS Link to comment Share on other sites More sharing options...
Solution DBCooper Posted April 12, 2023 Solution Share Posted April 12, 2023 How did you change it for plan views? If you double-click on the arrow tool, you can open the "general layout defaults" dialog to change it. You can also go into the defaults dialog and look for "layout" to get to this dialog. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 12, 2023 Author Share Posted April 12, 2023 Thanks DB, could have sworn I tried that - too easy and thanks for the help. Link to comment Share on other sites More sharing options...
