Where Is The Layout Bump Setting?
HumbleChief
Go to solution Solved by DBCooper,
  • Solution
How did you change it for plan views?
If you double-click on the arrow tool, you can open the "general layout defaults" dialog to change it.  You can also go into the defaults dialog and look for "layout" to get to this dialog.
