Barn Door - Hardware Issue
tkwebster
Is anyone else having an issue with the barn door hangers being way too tall? It just started happening in X15. If I put the "Height Above Door" on anything besides 0", they shoot all the way into the ceiling/attic area. It happens with all hangers (Core, Bonus, Manufacturer and User made). The only hangers that work are the "Use Default". I tried changing the default but it just did the same thing.
This is probably a result of the "Z" Stretch Plane or "Z" origin being at the wrong location in the Hardware Symbol.
OTOH, it might be a bug in the calculation using the door height to stretch the vertical pieces.
You should contact support for this.
This is a bug introduced in X15. Right now the only workarounds I know of are to use a parametric hardware style or to set the Sliding Track hardware Height Above Door to 0".
It will hopefully be fixed in the next update, but as always, you should still report it if you would like to see it fixed.
