pjames Posted April 7, 2023 Share Posted April 7, 2023 I'm having an issue where the garage door is not dropping and cutting out the foundation. Anyone know what's going on here? Can't attach the plan file as it's too large. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 7, 2023 Share Posted April 7, 2023 Take a screenshot of your main floor plan with the garage highlighted. Open the garage room spec dialog. Take a second screen shot of the d'box. Post both pics here. Alternatively: The building looks uncomplicated. Make a copy of the plan, strip it of everything except walls, roofs, doors, and windows. No cabinets, no furnishings, no furniture, nothing that can jack up the poly count. You should be able to get it to a size for zipping and attaching the compressed file here. Remind us to open it using X14. Link to comment Share on other sites More sharing options...
pjames Posted April 7, 2023 Author Share Posted April 7, 2023 Good idea - I took the walls out of the second floor but it should be enough for you to take a look at the issue. Thank you - any input is appreciated. Garage Door Issue.plan Link to comment Share on other sites More sharing options...
richoffan Posted April 7, 2023 Share Posted April 7, 2023 Open the door dbx > Rough Opening > Add for Concrete Cutout + establishes your MO for both swing and overhead doors. Link to comment Share on other sites More sharing options...
pjames Posted April 7, 2023 Author Share Posted April 7, 2023 Adding the concrete cutout did not change anything. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 7, 2023 Share Posted April 7, 2023 You didn't show a pic of the garage room d'box. Link to comment Share on other sites More sharing options...
Garybills Posted April 7, 2023 Share Posted April 7, 2023 In your plan it looks like the top of your garage floor is above the top of the stem wall. The door is not in the foundation to cut it. 1 Link to comment Share on other sites More sharing options...
richoffan Posted April 7, 2023 Share Posted April 7, 2023 is it showing in the foundation plan? Link to comment Share on other sites More sharing options...
pjames Posted April 7, 2023 Author Share Posted April 7, 2023 Ah my bad. Here is the room spec box. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 7, 2023 Share Posted April 7, 2023 Need to see the room below. The foundation. I'm in this thread with phone only . . . No Chief. Link to comment Share on other sites More sharing options...
Solution pjames Posted April 7, 2023 Author Solution Share Posted April 7, 2023 No worries! I solved my own issue - needed to set the absolute elevation for the stem wall top to 0 and the floor -6 for the garage. Then once I remade the foundation it dropped it properly. Thanks for talking it out! Link to comment Share on other sites More sharing options...
richoffan Posted April 7, 2023 Share Posted April 7, 2023 Based on Gary's observation (good call Gary) I just arbitrarily dropped your garage floor to be sure it was below the floor framing and the top of the stem wall and with the door spec set to show it cuts the foundation. You just need to adjust heights to suit your project. Checked 3D - works fine Hope this helps Link to comment Share on other sites More sharing options...
