BDesigns Posted April 2, 2023 Share Posted April 2, 2023 I have rendered quite a few walkthroughs and have never had this issue. The frames are choppy and unsteady no matter what I do. Has anyone else experienced this? Is there a remedy? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 2, 2023 Share Posted April 2, 2023 What frame rate are you using ? It needs to be at least 30 for a finished video and ideally 60. 1 Link to comment Share on other sites More sharing options...
BDesigns Posted April 2, 2023 Author Share Posted April 2, 2023 I was using 30 and even tried 45. Also turned down the compression to 30%. Tried rendering shorter splines and just interior shots. It all turns out the same. (See short clip attached) FullSizeRender.MOVFetching info... Link to comment Share on other sites More sharing options...
Chopsaw Posted April 2, 2023 Share Posted April 2, 2023 The .mov does not seem to want to download. Maybe post to your Chief Architect account or convert to .mp4 and I think the forum will host and play it for us. Link to comment Share on other sites More sharing options...
BDesigns Posted April 3, 2023 Author Share Posted April 3, 2023 Here is an interior shot. Hopefully this one works. Test Trim.mp4 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 3, 2023 Share Posted April 3, 2023 You haven't provided enough info for anyone to really help and you haven't done you Forum Signature either , so we don't have a clue what version you are using, camera type, or the hardware you are running it on. See Chopsaw's or My Signature to add some info to yours, so people don't need to ask every time you post ( I see you are new here ) https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 M. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 3, 2023 Share Posted April 3, 2023 On 4/3/2023 at 12:32 AM, BDesigns said: Here is an interior shot. Hopefully this one works. Expand Yup that works. Great design. Horrible video recording though. Let's figure this one out somehow. Post your plan or get tech support working on it. Do you have SSA ? Crank your FPS up to 60 just to be sure because that looks like about 20 for some reason. 1 Link to comment Share on other sites More sharing options...
BDesigns Posted April 5, 2023 Author Share Posted April 5, 2023 Thank you for the compliment! I dang near tried everything. I will reach out to tech support tomorrow. I completely redrew the plan and just focused on one room at a time thinking maybe I didn't have enough memory for all the materials I wanted and now some of the materials and finishes are blacking out during the rendering process. Something else is going on that is way above my paygrade. I appreciate your help and support. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 5, 2023 Share Posted April 5, 2023 On 4/5/2023 at 4:11 AM, BDesigns said: thinking maybe I didn't have enough memory for all the materials I wanted and now some of the materials and finishes are blacking out during the rendering process. Something else is going on that is way above my paygrade. I appreciate your help and support. Expand * thanks for doing the Sig. It may well be that you only have 2GB of Video Memory (Ram) which is the minimum, as Chief has recommended at least 4GB now for several Versions with 8GB being better and now recommended for X15, though being on a Mac you can't to PBR RTRT yet. I assume you are running the latest Drivers for your GPU? https://www.chiefarchitect.com/support/article/KB-02761/chief-architect-minimum-system-requirements.html#X15 Mick. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 5, 2023 Share Posted April 5, 2023 On 4/5/2023 at 4:11 AM, BDesigns said: Thank you for the compliment! I dang near tried everything. I will reach out to tech support tomorrow. Expand It could also be a codec issue. Xvid has been the best for me for a long time even before chief included it in the software package but not sure if it is compatible with mac systems or if that is even a consideration. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 5, 2023 Share Posted April 5, 2023 On 4/5/2023 at 7:10 AM, Chopsaw said: Xvid has been the best for me for a long time even before chief included Expand True, same here , it or x264vfw have been my goto's as well..... On Mac perhaps try HEIF or HEVC which I think both offer better compression. ( not sure about quality ) M. Link to comment Share on other sites More sharing options...
