Ed_Orum Posted March 22, 2023 Share Posted March 22, 2023 What do I need to do to get the siding from showing up on my Framing Overview. It does not show all of the siding, just some of it. Thanks in advance. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 22, 2023 Share Posted March 22, 2023 Looks like you changed the material of some framing members to something other than the default fir framing. Select one of those plates or studs and inspect the material. Report here what you find. Link to comment Share on other sites More sharing options...
Garybills Posted March 22, 2023 Share Posted March 22, 2023 Check your wall type and see if the sidling is marked as framing. I’ve had that before. Link to comment Share on other sites More sharing options...
Garybills Posted March 22, 2023 Share Posted March 22, 2023 8 minutes ago, Garybills said: Check your wall type and see if the sidling is marked as framing. I’ve had that before. Link to comment Share on other sites More sharing options...
Ed_Orum Posted March 22, 2023 Author Share Posted March 22, 2023 Thanks! The siding layer was marked as framing so that was the fix. 1 Link to comment Share on other sites More sharing options...
