Collada File editing
Hey there. Im trying to import collada files from sketchup 3d warehouse into X14. The issue im having is that usually there are additional items that import with the item that I want to use. When I try to edit the cad block  in Chief to delete the additional items it shows them as deleted the 2d view but not in the 3d view. Any help would be great.
See example of file... it has 2 simpson brackets. I only need one of them. model 2.dae
Simpson has a Chief library with many 3d symbols already.
These ones can pretty easily just be made from scratch as well.  I offer this type of thing as a paid service, but here's a quickly thrown together pair of symbols on the house.  These have less faces than the ones in the original dae file as well:
Custom Column Caps.calibz
Custom Column Cap 1.dae
Custom Column Cap 2.dae
The calibz file was made in X15 but you should be able to import the dae files into older versions.
    33278
    markstevens
    markstevens
