Lights on for two levels RT
mtldesigns
Go to solution Solved by Ryan-M,
Good morning pros.
I am wrapping up a approval design, and one of the final steps is that I take a couple RT camera views.  I come to this shot, and wondering how do I get both floors lights to show on?  Its a night view because I want that glow.  I have rooms above in this great room, that don't show on also.
Thank you in advance.
  • Solution
In the Adjust Lights Dialog, switch to using a Light Set and you can explicitly control which lights are on.  When using Automatic lighting, Chief will only turn on lights on the floor that the camera is on, starting in the room that the camera is in when a rebuild or refresh last occurred.
1 hour ago, Ryan-M said:
switch to using a (New, dedicated) Light Set
This should work, has for me in the past, just make a "Great Rm Light Set" and turn off everything not needed to be on in the house.....
