mtldesigns Posted March 4, 2023 Share Posted March 4, 2023 Good morning pros. I am wrapping up a approval design, and one of the final steps is that I take a couple RT camera views. I come to this shot, and wondering how do I get both floors lights to show on? Its a night view because I want that glow. I have rooms above in this great room, that don't show on also. Thank you in advance. Link to comment Share on other sites More sharing options...
Solution Ryan-M Posted March 4, 2023 Solution Share Posted March 4, 2023 In the Adjust Lights Dialog, switch to using a Light Set and you can explicitly control which lights are on. When using Automatic lighting, Chief will only turn on lights on the floor that the camera is on, starting in the room that the camera is in when a rebuild or refresh last occurred. 1 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 4, 2023 Share Posted March 4, 2023 1 hour ago, Ryan-M said: switch to using a (New, dedicated) Light Set This should work, has for me in the past, just make a "Great Rm Light Set" and turn off everything not needed to be on in the house..... M. 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted March 5, 2023 Author Share Posted March 5, 2023 11 hours ago, Kbird1 said: Great Rm Light Set" Worked as a charm. You ever have one of those days, where you just forget about a tool? Brain fog this AM I guess. Thanks! 1 Link to comment Share on other sites More sharing options...
