How to convert a pvc window section to molding
dskogg
Go to solution Solved by dskogg,
I am working on some 3d section details and I want to use a pvc window section as a molding.
I have built the polyline and subtracted the cores, when i make it a molding ca does not remove cores.
Is this possible to do? If so how do you do it?
