Mike's Symbol Spot
para-CAD
Same block.
Removed the interlocking "nubs"
Removed rebar.
Added concrete.
Only 36 faces!!!
I will be working on the corner blocks and the taper top blocks.  Once I get a few done, I'll compare them to Build Blocks and some of the other ICF vendors.
Once I get "smart" on these simple symbols maybe I'll try more cool/complex ones.
FOX BLOCK - 8 INCH TYP (125) 36 FACE.calibz
I used photoshop to create a 20" x 20" Texture Source png of the FOX BLOCK label.
Not sure if it has to be 20" x 20" but it worked so I won't mess with that.
So is it worth creating 3 sets of Texture Sources for the 3 axis' of framed wood, so that I can have all the wood grain oriented correctly when multiples are displayed.
I built a simple purlin but the wood grains are not correct.
3D - ROOF PURLIN (TYP).calibz
So here's an odd thing.  I created a 2D framing square but when I convert it into a 3D solid with 3/16" thickness, all of the numbers and lines disappear.  If I'm not doing something right, I'm all ears.  If this is just how it goes when converting 2D to 3D, I would really support the software design team finding a way to apply format-able text on 3D surfaces that skew the same as the surface.
2D Framing Square.calibz
I'm liking the Notes with schedule look (option B).  Not sure I will ever include such items since most of my AHJs are black and white 2D only in their preferred plan styles.
If I specify a detail as in, See 2/A14, I can further define it as
    See 2/A14, Note 4
or
    See Note (4),  2/A14
