DeniseR Posted January 26, 2023 Share Posted January 26, 2023 How do you create double barn doors for a doorway? I've looked in the Library and can't find it as an option, so I just assumed it would have to be created. I've tried putting two barn doors together but CA puts a post in between the doors. I need the doorway to stay open and each barn door on either side of the opening. I've attached a photo of what I need to create. Any help would sure be appreciated! Thank you! Denise Chief Architect X14 Windows 10, Intel i7, 11th gen, 8 core, 32 GB Nvidia, GeForce RTX, 12 GB Link to comment Share on other sites More sharing options...
SusanC Posted January 26, 2023 Share Posted January 26, 2023 Place a door in your plan. Double click on the door to open the dialog box. Select "Barn" door. Go to "Options" tab. Select "Door Panels" and then "Double Door Only". Good luck! Link to comment Share on other sites More sharing options...
DeniseR Posted January 26, 2023 Author Share Posted January 26, 2023 That was so easy! Thank you SO much! Link to comment Share on other sites More sharing options...
DBCooper Posted January 26, 2023 Share Posted January 26, 2023 It's actually even easier. If you just place a barn door and make it wider than 4', it will automatically turn into a double barn door. You only need to use the dialog if you want a double barn door that is smaller than 4' or a single barn door that is wider than 4'. 1 Link to comment Share on other sites More sharing options...
