Rander91 Posted January 24, 2023 Share Posted January 24, 2023 Hello everyone, I'm having an issue with my railing on one side being raised with some sort of a sill or framing member between the newels and deck boards. I cannot find any settings that are influencing it. I've attached a couple pictures and the .plan file. Thank you in advance and my apologies if this has been covered before or if I posted incorrectly, I'm very inexperienced with forums. Rear Deck Project.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted January 24, 2023 Share Posted January 24, 2023 35 minutes ago, Rander91 said: I cannot find any settings that is influencing it. I didn't either , might just be a Chief Anomaly as switching the Walltype to Deck Railing 6 , checking out what changed ( no extra flooring strip now) and switching it back to Walltype Railing 17 seems to have fixed it ....of course YMMV M. Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 8 minutes ago, Kbird1 said: I didn't either , might just be a Chief Anomaly as switching the Walltype to Deck Railing 6 , checking out what changed ( no extra flooring strip now) and switching it back to Walltype Railing 17 seems to have fixed it ....of course YMMV M. Thank you!!! Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 Just now, solver said: You did better than maybe 99% of new users. Good clear images, clear problem statement, attached the plan file -- well done. Thank you! I've been on these forums for a long time as a reader when I have issues and I've seen you ask for those things many, many times, so I made sure to follow those parameters at least. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 24, 2023 Share Posted January 24, 2023 8 minutes ago, Rander91 said: Thank you!!! I thought it might be a Room Definition or Wall definition Issue so was just trying a few things , so happy I found it , lets hope it stays that way and +1 on what Eric said , just had to open the saved camera to look around.... M. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted January 24, 2023 Solution Share Posted January 24, 2023 The floor heights are different on your landing than they are your main deck. Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 1 minute ago, Alaskan_Son said: The floor heights are different on your landing than they are your main deck. I'm not sure how that happened, thank you! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 24, 2023 Share Posted January 24, 2023 23 minutes ago, Rander91 said: I'm not sure how that happened, thank you! You bet. You might consider changing the "Solution". Modifying the wall type might help address the issue but its really just coincidental and isn't a proper answer. Changing the wall type just so happens to cause some breaks to occur that in turn separates that 1 long wall into 3 sections, placing the 2 remaining outside wall sections completely disconnected from that landing. The real problem is the floor height issue. Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 3 minutes ago, Alaskan_Son said: You bet. You might consider changing the "Solution". Modifying the wall type might help address the issue but its really just coincidental and isn't a proper answer. Changing the wall type just so happens to cause some breaks to occur that in turn separates that 1 long wall into 3 sections, placing the 2 remaining outside wall sections completely disconnected from that landing. The real problem is the floor height issue. You're right, its been corrected. Thank you! Link to comment Share on other sites More sharing options...
Kbird1 Posted January 24, 2023 Share Posted January 24, 2023 I missed that in the Camera View , though I'd still call it an anomaly . I am not sure why you used a landing there though ( didn't occur to me) instead of just shaping the deck as needed for the stairs each side? Mick. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 24, 2023 Share Posted January 24, 2023 4 minutes ago, solver said: It's a deck with a room name of landing. Yes, but why is it separate? why is it not just a bump out? it's at the same level , same materials etc , perhaps that's just how I'd do it.... M. Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 25 minutes ago, Kbird1 said: I missed that in the Camera View , though I'd still call it an anomaly . I am not sure why you used a landing there though ( didn't occur to me) instead of just shaping the deck as needed for the stairs each side? Mick. It's a replication of an existing structure that is getting a new roof structure. Link to comment Share on other sites More sharing options...
Rander91 Posted January 24, 2023 Author Share Posted January 24, 2023 Thank you for the help everyone! The design is complete and I figured I'd share it here as a thanks! Link to comment Share on other sites More sharing options...
