Steve_Matlaga Posted January 22, 2023 Share Posted January 22, 2023 Hello, As it relates to Library Browser; I'm curious to know if there are controls to shut off the auto-extend of a folder when you drop and drag an item into it. Then it opens up sub folders. This is fine normally. However, if you haven't gotten around to organizing a main folder, you may get a very long list of items. I have an easy work-around. I'll move my unorganized items into a folder name starting with a '0' zero, so it will stay at the top of the list. That just leads to this though once you now drop that item into the next sub folder; and the question remains. How to stop auto expand of a folder/sub folder. Any insight is helpful. Thanks, Steve Matlaga 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2023 Share Posted January 22, 2023 1 hour ago, Steve_Matlaga said: Hello, As it relates to Library Browser; I'm curious to know if there are controls to shut off the auto-extend of a folder when you drop and drag an item into it. Then it opens up sub folders. This is fine normally. However, if you haven't gotten around to organizing a main folder, you may get a very long list of items. I have an easy work-around. I'll move my unorganized items into a folder name starting with a '0' zero, so it will stay at the top of the list. That just leads to this though once you now drop that item into the next sub folder; and the question remains. How to stop auto expand of a folder/sub folder. Any insight is helpful. Thanks, Steve Matlaga I don't believe it's an Option, I too wish it didn't happen , as you have shown it can lead to some very long dropdowns. M. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 22, 2023 Share Posted January 22, 2023 No, there isn't any option currently to modify that behavior. It would be a good idea to submit it as a suggestion. Probably something in Preferences. 1 Link to comment Share on other sites More sharing options...
Steve_Matlaga Posted January 22, 2023 Author Share Posted January 22, 2023 17 minutes ago, Joe_Carrick said: No, there isn't any option currently to modify that behavior. It would be a good idea to submit it as a suggestion. Probably something in Preferences. Good idea. I'll put it on the list It's pretty picky of a thing to request. Guess we'll see if others chime in. Once you get your menu structure organized, it's not 'as bad'. 1 Link to comment Share on other sites More sharing options...
mkeeney Posted January 30, 2023 Share Posted January 30, 2023 Having the same issues, would definitely prefer to have the option to choose the drop-down in plans browser. Too much time wasted scrolling & trying to find the right plan file then scroll to find the right view or elevation, etc. Link to comment Share on other sites More sharing options...
