SkullMesaRanch Posted January 21, 2023 Share Posted January 21, 2023 I purchased the attached contour and perimeter dxf files from the county assessor office. Will someone see if they can view this lot in 3D? I have watched the videos and read the info on the forum. The files come in on the elevation data and terrain perimeter layers. Do I need to set an elevation to view it? ContourNAVD88_1268.DXF Parcel_20218001G.dxf Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2023 Share Posted January 21, 2023 It works just fine. You need to convert the appropriate layers to elevation data and terrain perimeter during the import process. Link to comment Share on other sites More sharing options...
SkullMesaRanch Posted January 21, 2023 Author Share Posted January 21, 2023 27 minutes ago, Alaskan_Son said: It works just fine. You need to convert the appropriate layers to elevation data and terrain perimeter during the import process. Thanks for checking the files so quickly. When I went back in and remapped the files, it worked. I assume in order to get this to work with my house plan, I'll have to enter elevation data. The upper level is about 2600'. Do I do this by "converting polyline?" Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2023 Share Posted January 21, 2023 3 minutes ago, SkullMesaRanch said: The upper level is about 2600'. Do I do this by "converting polyline?" No. Simply select the Terrain, and set the Subfloor Height above Terrain to be +/- 2,600 ft. You might have to play with that number to get it right where you want it. Link to comment Share on other sites More sharing options...
Doug_N Posted January 21, 2023 Share Posted January 21, 2023 if you have your building already done with no terrain specified, and then import the dxf file, the terrain will automatically adjust to the existing building. Then when you open the terrain specification DBX you can adjust the difference between some point of interest and the first floor in the dialog. Link to comment Share on other sites More sharing options...
