DH7777 Posted January 17, 2023 Share Posted January 17, 2023 I have been working with Twinmotion with my CA models but I have become frustrated in locating screen material to apply to my porch. Not sure where it is in Twinmotion or how to create it. I can apply any material to the surface of the "screen" that was imported from CA but there is no actual transparent screen in Twinmotion or Sketch fab. I have a screen porch that I would like to make the screen surface look real in my model (which means being able to see through the screen) but like I said there seems to be zero screen material to use. I need help please Link to comment Share on other sites More sharing options...
VisualDandD Posted January 17, 2023 Share Posted January 17, 2023 Lots of options. This took me 30 sec to make. It is a perforated metal. Re-scaled it and changed color to bronze. There are also mesh materials. Just resize, and color. On chief, set the screen material to a discrete material. (some type of glass that wont be used any other place). Then when you switch the material in TM only the screen porch gets changed. Link to comment Share on other sites More sharing options...
rlackore Posted January 17, 2023 Share Posted January 17, 2023 You can use the Grid 01 material, adjust the Color to black, Reflection to 0, Scale to around 1.25, turn Metalness off and Two-sided On. 1 Link to comment Share on other sites More sharing options...
DH7777 Posted January 17, 2023 Author Share Posted January 17, 2023 2 hours ago, VisualDandD said: Lots of options. This took me 30 sec to make. It is a perforated metal. Re-scaled it and changed color to bronze. There are also mesh materials. Just resize, and color. On chief, set the screen material to a discrete material. (some type of glass that wont be used any other place). Then when you switch the material in TM only the screen porch gets changed. okay thanks! Link to comment Share on other sites More sharing options...
