window reveal - no casing
ddaigle
10 minutes ago, ddaigle said:
Hello Fellow Chiefers!
My client wants to see window and door reveals , but no casing.
Any tips on how to achieve this?
Sample Pic attached of the desired effect
Thx!
Dru
is it really necessary to show the reveal? I would charge the client extra if that were the case.
Off hand, easy way is to use material regions/backsplash tool to cut parent layer and set assembled thickness to an 1/8"
Or a material region at each opening, use concentric to give 1/8 upsize, airgap material, 1/8 thick single layer, cuts into surface?
Aha!  It's 3/8 thick and cuts the 1/2 drywall.  Takes maybe 20 seconds per opening side.  Involved a CAD DETAIL FROM VIEW move to copy each window perimeter, then upsize by 1/8 concentrically, copy/paste-in-place in section or elevation, then the MR dialog.
I colored mine dark gray.
Anybody wanting the expense of this in a built job surely isn't going to balk at paying a Chiefer to model it in 3D, although it seems a folly to have it in on a screen just to see when there are photos of it all over Houzz.  You can trim in mahogany for the same cost of no casing plus reveal.
