Boston7 Posted December 28, 2022 Share Posted December 28, 2022 Hello all, Is there anyone can answer a roof question? The attached picture below is the actual bathroom and of course I have attached a proposed design. I have drawn the roof to have a pitch of -3. The angled roof is on a wall of 78" high, the rest of bathroom flat ceiling height is 95". Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 29, 2022 Share Posted December 29, 2022 In order to cogently respond you need to share a copy of the .plan file you have so others can edit it and tell you how they did so. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted December 29, 2022 Share Posted December 29, 2022 1 hour ago, Boston7 said: I have drawn the roof to have a pitch of -3 If you are having to use -3 (/12) for the pitch the Roof to make it look right ? the roof plane is facing backwards - ie drawn in the wrong direction..., in Plan view single click the roof plane grab the triangle and spin it 180° , then set the pitch back to 3/12. You could also just Use the ceiling plane tool in the 95" high bathroom , to show the slope above the mirror. Clg Planes draw the same as roof planes.... https://www.chiefarchitect.com/videos/watch/10149/where-to-draw-a-custom-ceiling-plane-inside-or-outside-of-the-room-s-wall.html M. 1 Link to comment Share on other sites More sharing options...
