Shed roof into Main roof
RayWeed
Go to solution Solved by Kbird1,
Gargage Roof.pdfHi, I'm using CA 12.  I am trying to add a shed roof from, in this case, a concrete apron, to the main roof of my structure (picture explains it much better than I am).  I know this is a loaded and broad question but how do you do this?  I can't find a tutorial online.   I think I have to add a post and beam on 3 sides to get a gable wall, but is there a way to make the two roofs tie together?  Any help would be appreciated.
Gargage Roof.pdf
29 minutes ago, para-CAD said:
I frame it like in the image using RPN and an HP50g to do the math
I'll stick to Chief I think, that 1st pic makes my head spin not being part rocket scientist :) .............
PS Ray you might want to check this CA Announcement before Jan.9th since you are on X12...
https://chieftalk.chiefarchitect.com/topic/37322-chief-architect-software-licensing-changes-beginning-january-10-2023/
https://www.chiefarchitect.com/licensing/
  • Solution
this should help Ray...... CA should join the two planes easily once setup correctly....
https://www.chiefarchitect.com/support/article/KB-01179/creating-an-attached-porch-or-carport.html
or
https://www.homedesignersoftware.com/support/article/KB-01086/creating-an-attached-porch.html
1 hour ago, Kbird1 said:
Thank you!  I don't know how I didn't see this before.  I've been frustrated for so long!!!  And thank you for the heads up about changes.
