3DS Export Error
AzjahGreen
You have a symbol in your plan, K-10493 (possibly a kohler toilet?), that has more than 65,535 vertices.  3DS export doesn't like this.  My guess is that it doesn't show up when you open the 3DS file in another program but maybe it shows up and is missing pieces.
One way you may be able to fix it is to replace the symbol with a generic one that has less surfaces.  I suppose you could also break the symbol up into two or more separate symbols but this would be a little bit more involved.
putting the error message into google ( rather than the Forum Search)  will often find another post about Chief Errors Here on the Forum..... DB is correct by the way , there are a few Kohler symbols with this problem and one option is to export .DAE instead as it has a much higher limit.
https://chieftalk.chiefarchitect.com/topic/25591-3ds-export-error/
