Home Designer 2023 vs 2018
Britt_P
1 hour ago, Britt_P said:
I presently have Home Designer 2018 and am considering upgrading to 2023.  Had done one project on the 2018 version.  Would like some input as to whether the upgrade would be worth it.
Thanks
This is the Chief Architect forums so most users will not have valuable information for this particular question.  Check out Home Talk which is dedicated to that software: https://hometalk.chiefarchitect.com/forum/5-qa/
One thing to consider if going 2018 to 2023 is that it may not run on older computers, so look closely at the Hardware requirements and perhaps add you hardware specs to your Forum Signature ( see Ryan's and mine for examples)  so others can give you the correct information.
  • 2 weeks later...
