ericepv
Go to solution Solved by DBCooper,
I need to draw his curved roof dormer but I'm having trouble with the windows.
I can't quite get the curve of the windows or the height of the upper sash right. I have tried both a Broken Arch and a Double Arch (Left/Right checked)
Any suggestions would be welcome.
Eric
:rolleyes:
17 hours ago, DBCooper said:
See if blocking the 4 rectangular windows first and then adding the arch to the block works better.
Thanks DB, that did the trick (I should have thought of that earlier :rolleyes:).
