Member Statistics
Similar Content
By marlem2000
I started working on a wall niche thinking I wouldn’t have any problem but the more I walk, the more doubts I get.
Here they go a good bunch of questions related to this:
- If I remove the frame of the wall niche I get a brown texture that I want to replace by the one I used on the floor of the room. How can I expand that one inside the niche?
- Then, is it possible to change the color of the wall niche inside (not the whole wall)?
- The same way, is it possible to change the color of part of the wall?
- Now related to the cross section view, it’s almost impossible to select some objects because there are other elements in front of them. How can I do that? And, at the same time, why some objects aren’t visible in this view?
I know; too many questions. Sorry!
By marlem2000
Hello!
I hope everybody is enjoying this year that’s ending.
I’d like making a question before 2023 comes. Is there a way to make some kind of “up holes” in a wall in order to set some puck lights up too?
First, I tried with a wall niche but it’s too thin. I don’t know if I’ll have to use a pony wall or other but I have never worked with them so I’m feeling a bit lost. Any idea?
Many thanks and Happy New Year!
By DRyeHD
I'm having a problem getting a deck to remain when I try to contain it under a roof. The function of the roofs to the covered deck are to make a covered walkway to the covered deck. I didn't know where to begin searching for this issue so I'm posting this.
The attached screenshot shows where I'm able to get the roof and deck to look right (4'-1") and where the deck room conflicts with the roof (4'-0"). Ideally, I would make these both 4'-0". When I try to adjust the deck rail in or out from the back of the house (shown at 4'-0") the deck disappears.
I have attached the .pln file. Any advise is appreciated.
Ingram2.zip
By mprovost129
Ever since I upgraded to X14 I've had an issue where the trim doesn't populate on some of my roofs / roof belts. Has anyone else had this issue? Maybe I should try reinstalling X14? These roofs were copied from the adjacent roof that has the trim and has the same properties. It just makes no sense. I sent a request to support, and they couldn't recreate it at the time.
220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip
