Auto Story Pole Dimensions Issue
armfx89
41 minutes ago, armfx89 said:
Hello,
A rookie question that I can't answer. See pic. Highest Ridge shows as 14 1/2' when using Auto Story Pole Dimensions but adding 9' + 5' 5 5/8" doesn't add up to 14 1/2' ??
"Smallest Fraction" settings are different for those two dimension Formats, so the program is rounding based on your settings. See your Auto Story Pole Dimension Defaults:
1607706457_ScreenShot2022-11-02at9_30_57AM.thumb.png.c98929395bcdd39fd0b5296699ff4f68.png
3 hours ago, armfx89 said:
14 1/2' ??
It is rounding up to 14.5 feet.
If you want decimal feet then don’t use fractions in the settings.
If you want feet plus inches then chose the proper “units” and then select “smallest fraction”
All done in the Default settings that Chris showed in his comment above.
