Black Mirror
rikdekker
Thanks Mick
I have played around with the different setting and cannot seem to show mirrored reflections unless the material is 'Mirror". Haven't tried a RayTrace because I virtually never use Ray Trace, Only Standard and physically based cameras.
Would be a really nice feature to have in Chief if the colour of the mirror could be changed. Tinted mirrored glass is quite common  especially for commercial building applications.
10 minutes ago, rikdekker said:
Thanks Mick
I haven't played with it but I think Chief's Mirror Material is the only one that reflects in STD View ?
 and unfortunately, it doesn't allow you to "Blend" the Pattern Color with the Texture which might make
a good Suggestion Over in that Forum.
Polished and Metal Propeties should have an Effect ( Show) in PBR but won't look like a true Mirror
On 9/27/2022 at 10:24 AM, rikdekker said:
Any idea how to make a black mirror? or at least show reflections on black glass tiles?
You can't always get what you want (where did I hear that?).
But in this case maybe you can get what you need.
If you use the Rainbow Tool to change the mirror "Material
Color" to Black and the "Material Class" to "General Material"
you can achieve a "Black Mirror" in Ray Trace (CPU), PBR
(GPU) and Vector views.
Here you go @rikdekker. Upon further consideration
I have come up with a simple workaround that will let
you tint your mirror glass any color and have it render
in all views including Standard View. All you have to do
is create a thin 3D Solid the dimensions of the mirror
glass and place it in front of the mirror. Now you can
assign a colored glass material to the solid and tint the
mirror any color you like. In the images below the top
and bottom mirrors in the center are default mirrors
from the library. The 4 mirrors flanking the stock ones
on either side are obviously tinted to different colors.
They will display in all camera types. Maybe this will
work for you until such time as your suggestion is
acted upon.
@Rich_WinsorI tried it again and discovered when the gradient slider on the colour wheel was all the way to the right (full) then there were no reflections but when I backed it of even a bit the reflections appeared. I assume  when the colour is full then it is no longer transparent even though the material is still crown glass.
Worked brilliantly! Thanks so much for your help!
