TonytheArcht Posted September 23, 2022 Share Posted September 23, 2022 I've searched over all materials in the library and in bonus libraries unable to find a wall material that alternates between skinny and wide planks. The closest material I can find is the "Board and Batten" siding which has fixed skinny battens and wide boards. I know about sizing the image but what I'd really like to find is a material that I can control for both plank sizes--say, 4" & 8", or 3" & 6", or 2" & 7", etc. Anyone have suggestions? Thanks, Tony. Chief Premiere X13, Dell computer, 64-bit OS, 11th Gen, Core i9, Windows Pro 11. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 23, 2022 Share Posted September 23, 2022 12 minutes ago, TonytheArcht said: I've searched over all materials in the library and in bonus libraries unable to find a wall material that alternates between skinny and wide planks. The closest material I can find is the "Board and Batten" siding which has fixed skinny battens and wide boards. I know about sizing the image but what I'd really like to find is a material that I can control for both plank sizes--say, 4" & 8", or 3" & 6", or 2" & 7", etc. Anyone have suggestions? Thanks, Tony. Chief Premiere X13, Dell computer, 64-bit OS, 11th Gen, Core i9, Windows Pro 11. You could always place material regions over your walls in an elevation view at the designation you would like and then take a screen capture and paste back as a material Link to comment Share on other sites More sharing options...
robdyck Posted September 24, 2022 Share Posted September 24, 2022 You can make a texture by using a rendered image of a modeled surface using Chief. Here's a bit of an example: I created a model of siding boards using 3d solids and spaced them with 7" and 3" exposures. I then replicated them up the wall in 10" increments. The 3d solids were painted a material to resemble a single siding board. I then rendered a image of the wall and cropped it so it would be seamless. I then created a new material using the cropped image as the texture file. It took about as long to create the texture as it did to type this up! Rendered image showing my model against my default wall: Cropped image: Image as texture painted on the wall: 2 2 Link to comment Share on other sites More sharing options...
robdyck Posted September 24, 2022 Share Posted September 24, 2022 I will post this texture in the Symbols and Content section of the forum. Link to comment Share on other sites More sharing options...
TonytheArcht Posted September 24, 2022 Author Share Posted September 24, 2022 Thanks to everyone. Much appreciated! Link to comment Share on other sites More sharing options...
