Wall and measurements dissappear when I click on it
jerryajohnson35
The only thing I could think of is that you somehow messed up your dimension settings.  I tried a number of different things though and couldn't get any results like you did.  The other obvious thing to try is a reboot.
Assuming these don't fix your problems, then you probably need to post your plan.  I bet someone could figure it out pretty quickly without all of the guess work.
It could be a couple of things but try this first.
Preferences>Appearance>Colors>View Colors>Selection Line and Selection Fill.
Are these settings the same as your background color?
Or better still, post the plan so that we are not guessing.
