drawing a dimension close to another deletes the dimension and does not create the dimension
SHCanada2
Not a bug.  Its intended behavior and been that way as far back as I can remember.  From the current Help Files:
To delete a portion of a dimension line
  1. Select any Dimension Tool aside from Angular or Auto Exterior Dimensions.
  2. Manually draw a dimension line over the segment that you wish to remove, dragging from extension line to extension line.
