Stucco fill
DRAWCO
7 minutes ago, DRAWCO said:
Got it. Now how can I make it stand out more? I tried making the line style larger but doesn't seem to make a difference.
It's not a Line Style , it is a Pattern , change the spacing if 12" is too "light" for the number of Dots you want - try 6", then 3" etc , until it's how you want it....
9 minutes ago, DRAWCO said:
Yes, I see the difference. I would like to change sand to something else, so it looks more like rough stucco.
If it is Rock Dash or similar try the Gravel or Pea Gravel fills in the Library instead of Sand, adjust the Scale once again as needed.
