SHCanada2 Posted August 27, 2022 Share Posted August 27, 2022 anyone know why? it alters how the foundation wall ends, and then i have to fiddle around with the intersection tool. and i tried making a partition wall 0 thickness but it would not work. I suppose i could do 1/16 or something, but i would rather find a more elegant solution. 19.08.2022_12.42.38_REC room divider.mp4 correct result after I fiddle around with the intersection tool .... Link to comment Share on other sites More sharing options...
glennw Posted August 27, 2022 Share Posted August 27, 2022 Sorry, but videos without some sort of running commentary are too hard for me to follow - you have sound, why can't you use it to explain what is going on? The first thing that springs to mind is that when you step floor or ceiling levels Chief substitutes a wall with thickness so that there is wall between the change in floor/ceiling levels. ie, you cannot have a zero width wall defining a change in floor and ceiling levels. Quote If a zero-thickness Room Divider separates two rooms with different floor and/or ceiling heights, its wall type will be changed to the current plan’s default Interior Wall so that the platform step created by the height difference can be enclosed. See Floor and Ceiling Platforms. 3 Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 27, 2022 Author Share Posted August 27, 2022 thanks, next time I will add the audio, my apologies Link to comment Share on other sites More sharing options...
