winterdd Posted August 8, 2022 Share Posted August 8, 2022 Can we not stretch the grip points on a wall to shape it? I even added a break on both sides and no luck. Trying to achieve the look shown below on a similar home. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 8, 2022 Share Posted August 8, 2022 5 minutes ago, ChiefUserBigRob said: Can we not stretch the grip points on a wall to shape it? I even added a break on both sides and no luck. Trying to achieve the look shown below on a similar home. No you can not, so either use solids as a facade on the sides, or use roof planes or anything else you can come up with 1 Link to comment Share on other sites More sharing options...
winterdd Posted August 8, 2022 Author Share Posted August 8, 2022 2 minutes ago, Renerabbitt said: No you can not, so either use solids as a facade on the sides, or use roof planes or anything else you can come up with Ahhhh I was hoping to avoid that but ok, sounds like a plan to me. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 8, 2022 Share Posted August 8, 2022 23 minutes ago, ChiefUserBigRob said: Ahhhh I was hoping to avoid that but ok, sounds like a plan to me. You can shape the front wall. Just the side walls that need filling in with some other method. Place the break along the top of the wall. Link to comment Share on other sites More sharing options...
winterdd Posted August 8, 2022 Author Share Posted August 8, 2022 Here it is with p solids. What I don't like is the fact it won't be shown as stud walls in plan view no matter what method is used and those separation lines are bugging me on the elevation view. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 8, 2022 Share Posted August 8, 2022 14 minutes ago, ChiefUserBigRob said: Here it is with p solids. What I don't like is the fact it won't be shown as stud walls in plan view no matter what method is used and those separation lines are bugging me on the elevation view. See solution above. Link to comment Share on other sites More sharing options...
winterdd Posted August 8, 2022 Author Share Posted August 8, 2022 17 minutes ago, Chopsaw said: See solution above. Ok so a break at the top. Cool. Guess the sides will be the only thing faked in. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 8, 2022 Share Posted August 8, 2022 1 minute ago, ChiefUserBigRob said: Ok so a break at the top. Cool. Guess the sides will be the only thing faked in. Yes and they will be a bit easier to mask in for the details. Still waiting for a solution from chief though after many many requests. Link to comment Share on other sites More sharing options...
