edcsteve Posted August 2, 2022 Share Posted August 2, 2022 Shift A Dims, does not erase or update, it just keeps adding more dimensions. is there a way for it to just update when Shift/A is used? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 2, 2022 Share Posted August 2, 2022 Auto Exterior Dimensions Should automatically remove and replace any previous Auto Exterior Dimensions unless you have previously edited those dimensions in any way. Per the Help files, any edited dimension "...will be marked as edited, so if Auto Dimensions are later regenerated, your changes will not be lost." Link to comment Share on other sites More sharing options...
glennw Posted August 3, 2022 Share Posted August 3, 2022 Have you tried turning on Auto Refresh in the dimension defaults? This will delete the existing auto dims and auto replace them when you change anything in the plan that will affect the auto dims. 1 Link to comment Share on other sites More sharing options...
