MAINEWOOD59 Posted January 21, 2015 Share Posted January 21, 2015 I started a new project with 2 different roof elevations, all cathedral ceilings and a loft in the center (taller) structure. I cannot get ceilings to open up for cathedral effect in the 2 attached wings?? New Rangdale plan. chieftalk.plan Link to comment Share on other sites More sharing options...
evergreen Posted January 21, 2015 Share Posted January 21, 2015 My first thought because of the skewed layout was the need to create the cathedral ceilings manually but then noticed the way CA framed the second floor/ceiling. Could be a couple of things going on. Not sure...maybe some of the roof/framing pros will chime in. Link to comment Share on other sites More sharing options...
glennw Posted January 21, 2015 Share Posted January 21, 2015 For a start, you need to build the roofs correctly. It looks like you have built them manually. The central higher roofs run straight through under the side roofs - wrong. These roofs will always look wrong from inside. I suggest that you use the auto roof builder and uncheck Ceiling Over This Room. Link to comment Share on other sites More sharing options...
MAINEWOOD59 Posted January 21, 2015 Author Share Posted January 21, 2015 I'd make the wings a single level and raise the ceiling/roof. Thanks for the help, guys. For a start, you need to build the roofs correctly. It looks like you have built them manually. The central higher roofs run straight through under the side roofs - wrong. These roofs will always look wrong from inside. I suggest that you use the auto roof builder and uncheck Ceiling Over This Room. I tried this and have posted a picture of the results. "I'd make the wings a single level and raise the ceiling/roof." Eric, How do I do this? I also need to create a 2nd fl. loft in the taller structure. Link to comment Share on other sites More sharing options...
evergreen Posted January 21, 2015 Share Posted January 21, 2015 I drew a ceiling plane in the main building and pulled the wall material up in the gable section of the wings. I do get some Z-fighting on gable wall over siding, changed surface material thickness but did not seem to make a difference, have to mess around a little on that one. Link to comment Share on other sites More sharing options...
