Lowered Ceilings - "Easy-Peasy"
Joe_Carrick
I often have rooms with lowered ceilings (below the standard floor ceiling height) and have developed a pretty simple way to do this without creating a separate ceiling plane.
Here's the basics:
  • edit the room's ceiling finish by adding 2x4 ceiling joists and an air gap
  • the air gap should be the amount the ceiling is to be lowered minus 3.5"
Typically I want to lower ceilings 0", 6", 12", 18" & 24"
To make this really easy I create a series of named "Style Palettes"  consisting of rooms with the above ceiling finish definitions.  The "Style Palettes" only have the following properties checked:
  • Ceiling Finish
  • Ceiling Structure
  • Has Ceiling
I put those 5 Style Pallets in my User Library Folder "Furred Ceilings".
Now, when I want to change a room's ceiling height  I just select the desired Style Palette and "paint the room" with that style.
This is a big time saver. B)
If you want more options you can just copy-paste one of the Style Palettes, rename and then edit the room's ceiling finish.  That's a very easy way to add additional options.
  • Like 3
  • Upvote 4
  • 2 weeks later...
