ElizGuseva Posted June 28, 2022 Share Posted June 28, 2022 Hi! I've been trying to import the survey for 2 weeks now. I am doing everything as shown in the attached video in the link. But for some reason, when I assign the perimeter function to a polyline with the terrain perimter function, my cont-mjr layer disappears. It's on, but the lines disappear. As a result, the perimeter on the camera is flat but faithfully limited. If you can please explain the problem and how to fix it. Thank you! https://www.chiefarchitect.com/videos/watch/1056/import-a-surveyor-dwg-file-for-a-site-plan-or-terrain-perimeter.html?playlist=101 ACAD2010-Lot1-topo-arch.dwg Link to comment Share on other sites More sharing options...
rlackore Posted June 28, 2022 Share Posted June 28, 2022 I didn't watch the video, but the import works for me in X14: I imported only three layers: prop-bdry > imported as terrain perimeter cont-mjr > imported as elevation data cont-mnr > imported as elevation data Link to comment Share on other sites More sharing options...
ElizGuseva Posted June 29, 2022 Author Share Posted June 29, 2022 Wow! Could you show me the settings for importing please? Link to comment Share on other sites More sharing options...
Mark3D Posted June 29, 2022 Share Posted June 29, 2022 what version of chief are you using Link to comment Share on other sites More sharing options...
ElizGuseva Posted June 29, 2022 Author Share Posted June 29, 2022 X12(64 bit) Link to comment Share on other sites More sharing options...
rlackore Posted June 29, 2022 Share Posted June 29, 2022 5 hours ago, ElizGuseva said: Wow! Could you show me the settings for importing please? I believe these are the important parts of the import process: You should get this: Link to comment Share on other sites More sharing options...
