cburgess8 Posted June 21, 2022 Share Posted June 21, 2022 Imported this plan into X14- This home is monolithic slab set to 0- with -3.5" porte-cochere, garage and porches - terrain points start at 0 and work outward to -3'. It looks to be some kind of issue because of the retaining wall? not sure. I tried attaching the plan file in a compressed folder but it says its too big. Attached pic instead. Any help appreciated! Thanks! Link to comment Share on other sites More sharing options...
MPDesign Posted June 21, 2022 Share Posted June 21, 2022 (edited) It looks like the terrain is set to 36" below main floor 0. Open the terrain dbx and set it to +4". Edited June 21, 2022 by MPDesign changed "set it to -4" to +4 Link to comment Share on other sites More sharing options...
Solution rgardner Posted June 21, 2022 Solution Share Posted June 21, 2022 Attach a link to a cloud share file of the plan. Best guess from the view is that your terrain region for where the house is sitting is missing or not set to 0 Terrain is dropping down to the only elevation information it has which is the -36" that you have on the plan. Link to comment Share on other sites More sharing options...
cburgess8 Posted June 21, 2022 Author Share Posted June 21, 2022 THANK YOU BOTH!! started my Tuesday with a total brain fart. Back rollin! Link to comment Share on other sites More sharing options...
