teewhite7 Posted June 5, 2022 Share Posted June 5, 2022 Does anyone have info regarding this topic? https://www.chiefarchitect.com/support/article/KB-00797/creating-a-soldier-course.html Im having trouble creating molding profiles like this on X14 it seems like there's a new dialogue menu when converting Psolids - note the link i shared would be from a previous version & no longer accurate. Link to comment Share on other sites More sharing options...
Dermot Posted June 5, 2022 Share Posted June 5, 2022 "Polyline Solids" are just called "3D Solids" now. I'm not sure anything else that is different should really affect the article. If you are still having problems, then maybe you could explain in more detail. Link to comment Share on other sites More sharing options...
rgardner Posted June 5, 2022 Share Posted June 5, 2022 As I said in your other post that you deleted you don’t need a solid you need to draw the profile with a closed polyline and save to your library as a molding profile. Then set your window lintel to that profile. Link to comment Share on other sites More sharing options...
teewhite7 Posted June 5, 2022 Author Share Posted June 5, 2022 Rgardner, that's not working, there's something else that's not allowing this to work in X14 I've got several molding profiles i use as casing that were made with x13 the same method referenced in that link. I see what you're saying that they don't need to be solids, but still doesn't fix this particular issue Link to comment Share on other sites More sharing options...
rgardner Posted June 5, 2022 Share Posted June 5, 2022 On 6/5/2022 at 7:05 PM, teewhite7 said: Rgardner, that's not working, there's something else that's not allowing this to work in X14 I've got several molding profiles i use as casing that were made with x13 the same method referenced in that link. I see what you're saying that they don't need to be solids, but still doesn't fix this particular issue Expand Is it able to be added to your user library as a molding profile? If not are you sure it is a "Closed" polyline??? Are you able to set those molding profiles you already have to the lintel? If not then you should reach out to Technical support or post a plan here. The reason I say that is because: 1 Link to comment Share on other sites More sharing options...
