BrentJohnJohn Posted May 28, 2022 Share Posted May 28, 2022 Greetings, I know there has to be a simple way to change the following for the same Wall Type, instead of individually selecting each wall and editing. 1. Changing Wall Cap color. 2. Changing Wall Color. See attached. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 28, 2022 Share Posted May 28, 2022 Are you saying that changing the Walltype Definition does not work? at least for No#2 ? M. Link to comment Share on other sites More sharing options...
BrentJohnJohn Posted May 28, 2022 Author Share Posted May 28, 2022 Kbird, I just figured out how to change all the Wall Color - No #2. I'm still stuck on how to change the Wall Cap color. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 28, 2022 Share Posted May 28, 2022 19 minutes ago, BrentJohnJohn said: Kbird, I just figured out how to change all the Wall Color - No #2. I'm still stuck on how to change the Wall Cap color. Material Eye Dropper off the desired color , spray on ones to be changed is likely the easiest......... ( but not recommended for all applications - see below ) https://chieftalk.chiefarchitect.com/topic/31850-paint-can-tool-material-painter-best-practices/?tab=comments#comment-250698 https://www.chiefarchitect.com/support/article/KB-00793/using-the-different-material-painter-modes.html M. Link to comment Share on other sites More sharing options...
MarkMc Posted May 28, 2022 Share Posted May 28, 2022 Match Properties Clear all then select layer, floor and height (unless you did something not default) Open DBX, material tab, change color 1 Link to comment Share on other sites More sharing options...
BrentJohnJohn Posted May 28, 2022 Author Share Posted May 28, 2022 Thank you all for your help! Mark - I tried and it worked great!! Link to comment Share on other sites More sharing options...
