Show sets of polylines by view
GregMB
I have a Water Supply view and a Drain Line view.  I want to show Hot and Cold water supply ONLY in the Water Supply view and Drain Lines ONLY in the Drain Line view.
I am using polylines to draw my water supply and my drain lines.
How can I show ONLY Water Supply in one view and ONLY Drain Lines in the other?  It seems I can only show ALL polylines or NO poly lines.
What am I missing?  Is there a way to do this?
1 hour ago, jasonn1234 said:
open up the water polylines and assign the new layer
Or use the layer eye dropper painter tool to set the layer to the different items you don’t want to see in that view.
I will add that you also need to:
1 hour ago, solver said:
Learning about Layers.
And saved plan views
