LeRoyWells Posted May 12, 2022 Share Posted May 12, 2022 HI Can someone please tell me why the total heated sqft is not showing up Thank You John Reddell Rev 1.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12, 2022 Share Posted May 12, 2022 On 5/12/2022 at 6:45 PM, solver said: Are you asking about the Living Area Label? Being heated has no bearing on what shows. Obviously "heated" has a different meaning in AZ than it does in TN but being from further north heated to me is the same as a "conditioned" room of which certain types of rooms are not and generally those rooms are also not tallied as living area. So if the label will not appear by turning it on in General Plan Defaults the trick is to run Plan Check and that should restore it. Link to comment Share on other sites More sharing options...
Catch22 Posted August 22, 2022 Share Posted August 22, 2022 On 5/12/2022 at 7:32 PM, Chopsaw said: So if the label will not appear by turning it on in General Plan Defaults the the trick is to run Plan Check and that should restore it. thanks for the help. I researched this issue and found this post and it worked. Thanks Link to comment Share on other sites More sharing options...
