Roofs won't align
JasonJFBdesign
If the baseline, fascia top are the same but out of symmetric alignment when you join the ridges then the Baseline location must be out of sync with the adjoining roof planes (baselines commonly are located on the outer edge of framing of the walls they bear on.) Check for that.
To confirm that both roof planes are identical, select them both at the same time and open the dbx.
Any different settings will have either No Change or a horizontal bar in the selection box (or whatever it is called).
