msmith964 Posted April 28, 2022 Share Posted April 28, 2022 Hi all, So I have had this problem before and have now tried all the solutions that worked in the past but cannot fix the intersections of 2 exterior walls and an interior wall. It leaves a gap in the drywall. I am attaching file so hopefully someone can help me. I have circled the area which is in the Family room. Also, can someone tell me why everything is showing up black? I have lost the color display for the layers. thanks!! (FYI - I had to delete the second floor & zip it due to file size.) floor plan - test.plan.zip Link to comment Share on other sites More sharing options...
msmith964 Posted April 28, 2022 Author Share Posted April 28, 2022 Thanks for the toggle info.! Must have hit by mistake. I fixed the jog but I still get this. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 28, 2022 Share Posted April 28, 2022 Have you tried the Wall Layers Edit Tool? more info here https://www.chiefarchitect.com/support/article/KB-00033/adjusting-wall-connections.html Mick. Link to comment Share on other sites More sharing options...
msmith964 Posted April 30, 2022 Author Share Posted April 30, 2022 Hi. I tried this and it did not work. Did it work for you? Link to comment Share on other sites More sharing options...
Solution CharlesVolz Posted April 30, 2022 Solution Share Posted April 30, 2022 Your wall layers are not set up correctly. Link to comment Share on other sites More sharing options...
msmith964 Posted April 30, 2022 Author Share Posted April 30, 2022 I tried this as well, multiple times. No luck. Link to comment Share on other sites More sharing options...
msmith964 Posted April 30, 2022 Author Share Posted April 30, 2022 Charles that is it!! Thank you! Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 30, 2022 Share Posted April 30, 2022 You are welcome! Other considerations may be: lack of rain screen or a moisture barrier on exterior of exterior wall lack of air spacing or furring on interior of exterior wall using CMU at 8 inches instead of 7 5/8 inches 1 Link to comment Share on other sites More sharing options...
