HumbleChief Posted April 17, 2022 Author Share Posted April 17, 2022 2 minutes ago, robdyck said: If you change interior walls to a different layer, then when / if you change some of those to invisible, or no-locate, or railing, you'll need to manually change their layer as well. I see that now that you point that out. I like the flexibility of different wall layers but not sure where the benefits stop and start. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 17, 2022 Author Share Posted April 17, 2022 7 minutes ago, robdyck said: ...you'll need to manually change their layer as well. This is super easy and will experiment with this for a couple plan sets and see where it goes. Thanks for the help and feedback. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 17, 2022 Author Share Posted April 17, 2022 I renamed the Walls, Normal layer to Walls, Normal EXTERIOR. It generates the proper attic walls on the proper layer and should get me into more trouble down the road but I'm going to try it out. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 17, 2022 Share Posted April 17, 2022 I think it would make a lot of sense if "Wall Types" could assigned a default [exterior, interior, railing, none,etc....]. Then the software could know and inform if a wall was being edited to a type that wasn't appropriate - allowing the user to accept of reject. 1 Link to comment Share on other sites More sharing options...
