BrentJohnJohn Posted April 10, 2022 Share Posted April 10, 2022 Greetings, I have looked for the past 2 hours, yet cannot find a way to change the thickness of a line. I am wanting to create a thick/heavy line and cannot find a way to do so. I have attached the Line Specification and changed the Weight to 150. Yet, the line appears to be the same thickness of all the other lines (I did press enter and re-opened for example). Link to comment Share on other sites More sharing options...
BrentJohnJohn Posted April 10, 2022 Author Share Posted April 10, 2022 Yep, that was what I needed to do. Thank you much!! Link to comment Share on other sites More sharing options...
jskoch1000 Posted November 28, 2022 Share Posted November 28, 2022 This is also what I need to do. Did you get an answer? Thanks! Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 28, 2022 Share Posted November 28, 2022 2 minutes ago, jskoch1000 said: This is also what I need to do. Did you get an answer? Thanks! Do you have View > Line Weights toggled on? It may also be on one of your toolbars: Link to comment Share on other sites More sharing options...
jskoch1000 Posted November 28, 2022 Share Posted November 28, 2022 You are my hero. Thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted November 29, 2022 Share Posted November 29, 2022 Or, turn on print preview. BTW, this also affects how line styles will look. In both cases though, you need to make sure your drawing sheet is setup correctly or they won't be accurate. Link to comment Share on other sites More sharing options...
