RAILING WALL AND POSTS
winterdd
When using a railing wall and utilizing it's properties to produce the posts and beams, why won't CA dimension to each post? If manually dimensioning them it doesn't snap to anything for proper dims. Just another thing I got used to doing but obviously I need to improve this.
  • winterdd changed the title to RAILING WALL AND POSTS
  On 4/2/2022 at 1:33 AM, ChiefUserBigRob said:
yep.....is that running dims?
Expand
Yes but that does not really matter.  If your railing is symmetrical just go ahead and break it at the posts and reverse every other section and dimension away....     Use the dimensions to place the posts exactly where you want them.
Expand
Cool, it is sometimes easier to just draw the beams manually and add the columns from the library as well. But I am going to try your method too.
I generally place all my posts and beams manually. This way, I can set them exactly how I want them as well as making everything dimension the way I want to. Really doesn't take long. I also put them on their own layers.
